Submissions
This year, WATERS will accept two types of submissions: regular papers and challenge solutions.
Regular papers
Submitted papers should follow the IEEE conference format (2 columns, 10 pt, single-line spacing) and should not exceed 6 pages in length. Papers must be submitted in PDF format. The papers will be reviewed by the workshop program committee and all accepted papers will be made available to all participants one week before the workshop so that contributions can be examined prior to the event.
Papers should be submitted by using the easychair conference management system. The system acknowledges receipt of each submission by sending an e-mail to the contact author, and it allows revision of a submission until the deadline. In order to submit a paper, use this link:
https://easychair.org/conferences/?conf=waters2015.
By submitting a paper, the authors agree and confirm that: neither this paper nor a version close to it is under submission or will be submitted elsewhere before notification by WATERS 2015. If accepted, at least one author will register for WATERS 2015 by the special registration deadline set in the notification of acceptance, and present the paper at the workshop in person. A copy of the proceedings will be made available online. The copyright remains with the authors.
Challenge solutions
Papers must describe a (possibly partial) solution to the challenge and present the strengths and limitations of the used approach. Authors are strongly encouraged to implement their solution in a tool and make it available along with the submission. They will be able to present it at the interactive demo session. Each paper should also discuss how long it took the authors to understand the challenge and how much effort it took to solve it.
Submitted solutions should follow the IEEE conference format (2 columns, 10 pt, single-line spacing) and should not exceed 6 pages in length. Papers must be submitted in PDF format. The papers will be reviewed by the FMTV challenge committee. All accepted solutions will be made available to the participants one week before the workshop so that contributions can be examined prior to the event.
Challenge solutions should be submitted by using the easychair conference management system. The system acknowledges receipt of each submission by sending an e-mail to the contact author, and it allows revision of a submission until the deadline. In order to submit a solution, use this link:
https://easychair.org/conferences/?conf=fmtv2015
By submitting a solution, the authors agree and confirm that, if accepted, at least one author will register for WATERS 2015 by the special registration deadline set in the notification of acceptance, and present the solution at the workshop in person. In addition, your submission implies that you agree to participate as a reviewer to the (light-weight) evaluation of contributions submitted by others. The copyright remains with the authors. Depending on the participation, a joint publication of the challenge solutions will be considered.
